I can’t run Corona A6 Final on macOS Sierra - R18,here is bugreport;
http://www120.zippyshare.com/v/6gbAp0jX/file.html
Hi, could you please install the following special testing build and send us the error message if here will be some? Thank you
https://drive.google.com/file/d/0B7xyYS3daSJ7QkJEaGE5bXpCRnM/view
Hi, thank you for screenshots. I probably found the cause of this problem but I need to do more test.
perfect nikolat… thanks again for your fast support.. ![]()
Thank you very much for your help,I will be wating,happy new year,good luck ![]()
Hi, GokhanB
Can you tell us, whether this issue is already fixed for you? Thanks
I’m really excited about the latest developments.. but I am working very hard now,I think I will try tonight and I will definitely write the result.
Thank you for your interest and your help.
Greetings to the team. ![]()
