Hi Corona is crashing my C4d file every 5-10 min. It happens alot when I go to render marked takes. Running Build timestamp: Oct 8 2020 02:08:49 Version: 6 hotfix 1
For crashes, please always send us the bug reports.txt. See https://help.c4d.corona-renderer.com/support/solutions/articles/12000033461-how-to-report-issues-c4d on where to find it. Thanks!
1604420964_BugReport.zip is my bug report upload I am running C4D R23.008 (Build RB32902) and Corona 6 hotfix 1 Timestamp Oct 8 2020 02:08:49
Seems to always crash when I stop VFB and render marked takes. It freezes other times but this is happening every 5-10 min. Cinema says it’s a problem with Corona and Arnold is not crashing when using it. I need this for work so please help ASAP if you can.
We are aware of an issue that makes C4D crash if takes are rendered on top of ongoing Corona VFB render. Please, make sure that you first stop active Corona VFB render before proceeding with rendering the Takes.
Let me know if this helps with the crashes.
Thanks I’ll try this
