I have created a small scene, using only background texture.
I have set up a Corona Camera in a proper 0;0;135 position and used Corona Cam target to animate it on “autokey” white IR was on.
Jumped from Frame 0 to 100 to set the motion on “Default In/out” Set to Linear (Im not sure If that is important).
When both target move and camera settings animation were set, I have started to move on “track bar” to check if the motion is right.
Corona Camera Target started creating “key” for each spot randomly. Making the Animation uneditable as it filled in all gaps as it pleased.
also in the end the rendered frames were tottaly different than those shown in viewpot, target motion was done in 20-30 frames and camera animation settings were working properly
Regards
Fake_test.zip (5.15 MB)
