i have a question about the object visibility for the corona cam, i need to do some light study for a new building so i want to disable the roof so i can see how the light can impact on the interior of the building…
i add the roof to the visibility exclude from the cam, but also the shadow from it it will be disable…there is a way to still have the shadow from the roof?
Another way is to select the objects that should be invible and uncheck “visible to camera” in their object properties. It works with both standard cameras and Corona cameras.
If the roof is a simple geometry (like a single block) using just one material, then another solution would be using the rayswtich material to store the original material in reflect, refract, and gi slots, and leaving the direct visibility slot empty.
