Corona Color - Copy/edit Hex color
Hello
Was just working on some project and noticed that I have small issue with corona Color
When I copied hex color from photoshop I waned to change the values a bit, but its impossible to do so when hex is imported.
So I decided to copy the Result, but wasnt able. When I click the “solid color” the hex RGB value disapears.
So I need to remember the RBG values (not much but its annoing) then I can edit the color.
Can you “open” the “Result” to be copied? There are many options to do that other way, but… That would be quite nice.
