Corona Color Correct <-> Color Correction / Output?
Is it possible to 1:1 convert a Corona Color Correct map to the generic Color Correction / Output maps?
For example,
  1. Is Corona Color Correct map, gamma: 0.9 == Max Color Correction, gamma =0.9?
  2. Is Corona Color Correct, Temperature / Green-magenta tint == Max Color Correction, Hue Tint?
  3. Is it possible to 1:1 replicate Corona Color Correct Curves in Max Output Color Map?
Looking for some feedback on this. Our studio needs to convert a huge material library to use the default 3ds Max color correction maps (Color Correction, Output, etc.), but at this point all I can do is conduct individual tests for each parameter to determine the corollary between each parameter, including curves.
