When converting Roughness to Glossiness, it is not correct to ‘invert’ using the Corona Color Correct map, but you can ‘flip’ the white and black points using the curves(?)
EDIT: ‘flip’ the white and black points using the curves, but you can ‘invert’ using the Corona Color Correct map(?)
Why it is not correct to invert using Corona CC node and what is the difference between “inverting” and “flipping black and white points in curve editor”?
Indeed, you’re right. I’ve compared it to the max’s native output node and it looks like invert colours in Corona CC node is broken. Moving topic to bug reporting.
Haven’t tried the native Max, but I did this - took a bitmap, put it through two Corona Color Corrects, one using Invert, one using the “reversed curve”. I then screengrabbed, copy-pasted into Photoshop, duplicated, and inverted the duplicate there. The Corona Color Correct invert, once inverted again in Photoshop, matches the original (and the Photoshop Invert matches the Corona Color Correct invert).
The Corona Color Correct curve change, however, looks very different from the Photoshop invert result. So, to me, it looks like the Invert in the Corona Color Correct is working as expected, and either there’s a problem with the curve, or there’s just a misunderstanding as to what the curve does. As to what Max native invert is doing, not sure
Tom, when you test it in photoshop, don’t forget that inevitably there’s gamma involved. I did my test in linear and i think, it’s pretty obvious which node is broken (see attachement).
You are correct - swapping curve’s endpoints = invert.
The issue here could be that Roughness map by standard, is authored at Gamma 1.0 (technically glossiness should be too but that isn’t any standard and everyone uses gamma arbitrarily).
So if you want to convert Quixel/Substance Roughness map into correct and expected glossiness result, you need to also use gamma outside of invert, because the invert alone is only in sRGB space (it’s in sRGB space tab).
Juraj’s explanation seems to be correct. It seems that “invert colors” and “invert curve” operate in different gamma/color space.
I am attaching an example with a possible workaround.
I will now report it to the devs, but keep in mind that this may be the expected behavior.
Man, this came back to bite me again. Maybe there should be a warning in the curve editor(?) Was there some consensus from the devs about this, or is it too niche of an issue, or already well understood by most of the user base?
