Hi all,
it would be possible to modify Corona Color Correct Texmap as the attachment?
Now i have to create one Corona Color Correct Texmap for each maps, but in the way i suggest, i need only one Corona Color Correct Texmap for all maps tath needs the same Colo Correction.
That’s why that map can be “remote controlled” already: pipe all your maps through CCC (CoronaColorCorrect) where you need it, and plug one additional (or one of the used ones) into the “Use settings from map” slot. Then you can controll all connected CCC maps with that single one.
I suggest usign what Frood recommended. With multiple inputs, it would not be obvious which output to use where - you would still have to somehow specify, that for material X you want to use output 2 and for material Y, output # 5
