corona color map crash
Hi guys, the corona color map is crashing scenes when you try to make it visible on viewport, daily build 02-11-15, also if the scene is saved with that map assigned to be vissible at viewport it crashes when you try to open the max file.
it works here, can you send me the scene where you are having problems?
fixed in 1.00.02
