Corona Converter - unable to process Vray materials/maps
The converter is unable to read/convert materials and maps from Vray unless you have Vray installed.
In the past, this issue was solved by installing the Vray demo, and even after it expired, the converter could use it to read Vray materials.
Since Chaos changed their policy, Vay is now a one-time trial, and it’s not possible to download it again once your trial has expired.
This poses a problem when you update 3dsmax or get a new computer, since you cannot download Vray again. I see no other option than having to buy the full version of Vray… which really isn’t worth it to me. This does imo defeat the purpose of the converter, rendering it useless.
Do you see any other solution? I think Chaos ought to be able to include the files necessary to make the converter fully functional without having to install Vray.
You should be able to download the V-Ray installer even if your trial is expired from here: https://download.chaos.com/
Let me know if it does not work for you.
Great! Problem solved. Had no idea that page existed.
Still, having to install all of Vray just to get the converter to work seems rather inconvenient. Wish the converter would work without Vray installed.
