Hi with the new server change I updated to the latest corona version and noticed corona converter was working randomly- i.e sometimes converts from vray to corona, sometimes doesn’t. Re-installed corona, reinstalled vray and still the same thing. Sometimes it works, and others it doesn’t. The thing is that when I’m working with corona materials across my scene there’s no problem, but if there’s a vray material somewhere, maybe from an old block or something, and that I haven’t been able to convert, max crashes when rendering while parsing. No errors of any sort show up. Just a blank frame buffer. I’ve found that the only way to avoid this, after finding the culprit material, is to restart max and try corona converter until it works again. Such a shame as the converter worked so nicely previously…
using max 2022, and 64gb of RAM with latest corona
thanks
As far as I know, the converter doesn’t have anything to do with Corona or V-Ray licensing. If your license is activated, you should be able to use all the render engine’s features. If something is not consistently working for you, please contact us about it at https://support.chaos.com/hc/en-us/requests/new
