I am a vray user and planning to shift to Corona. However whenever i render my scene in Corona, I get very washed out image. Probably due to incorrect gamma settings ?
When i save the image, it looks much better. My Gamma settings -
In Max’s preferences set output gamma to 2.2 (set 2.2 everywhere). Don’t touch Corona’s internal gamma settings. When saving a .jpg check “use system settings”, when saving .exr, .hdr or other 32-bit file, check “override gamma” and type 1.0.
I did set output gamma to 2.2. I still get very washed out render in Corona VFB. Every time i need to check “override gamma” to 1.0 while saving an image. Desperately need a fix.
This answers my question. I did use over bright materials in my scene, hence the washed output. I did a test with Corona default grey material under “Override material” rollout and it was rendering just fine.
Where are Corona gamma settings? I couldn’t find it anywhere.
Thanks a lot !
Sorry to bombard you with questions, So, technically we cant use values above 220 in Corona(Even if we want to render white walls for eg, we need to use slight grey material ?) and what about textures ? What if i have to render white marble in my scene, every time i need to tone down my texture in Photoshop ? And lastly, how do i know if my texture is below 220 value in RGB ?
RGB in color selector under 3DS MAX is determined with “Value” parameter, correct ?
If your bitmap has some very bright spots and you are using it in diffuse slot, you can lower the “diffuse level” value to 0,7 - 0,6 - 0,5 depending on what you want. In reality materials are hardly ever so bright. See:
You can also use albedo render element to determine if some parts of your scene are too bright.
