Corona crash AMD Ryzen 3900x
Hello everyone. I’m having some issues with corona V5.
I am an architect and I am trying to visualize the exterior of the building. I have a lot of lighting, a lot of lawn and trees made through proxies. The image renders to 60-80 passes and then catches bluescreen.
AMD Ryzen 3900x, 64Gb Ram. CPU temperature maximum 80 degrees Celsius without overclocing. Let me mention that after overclocking on AMD Ryzen, the picture rendered up to 6 -10 passes and crashed.
Has anyone had a similar case?
Try a stress test app like Prime95 to see if your system is stable under high CPU load.
Your issue looks rather like a problem with your rig than with Corona itself.
The 80°C should not be a problem, though, your CPU allows higher temperatures.
CU
Michael
As a note, Corona can never cause a blue screen. When those happen, it comes down to hardware or drivers, could be anything from overheating, to faulty memory, to an outdated driver, etc.
