I have a scene which I tried to render and didn´t get any result cause Corona crashes after getting passed the 100 and plus passes.
What can I do?
I had a scene made in vray and I converted all materials into Corona´s materials.
And so far so good it renders until certain point.
Now. Hear this.
I´ve tested it in 2 3770k intel core i7 FAILED both 16gb ram
also tested in another core i7 ASUS based 12gb ram netbook from republic of gamers FAILED
But tested it in a AMD T1100 core and work pretty good and easy. Last time I´ve look it was running the 306th pass without crashing.
Last night I render it with another camera angle, and without the vray obj. It went until 9hs of render without crashing in one of my i7 3770k.
I will still keep running tests in other machines though.
I think I gave you the scene without that vray mat. So It shouldnt cast any red light or crash if it was that.
Last night I have done a render again in the same i7 and its still rendering.
since the current build is very different from the A5, I dont think it is worth letting it render for ~10 hours to see if it still crashes. But I might be able to do something with a crash minidump from a recent build
Im still trying the scene in 2 different i7 with the same characteristics and settings and one renders the scene and the other doesnt.
Tell me if you need more information.
