Not sure if this is a bug or not, but I’m getting fairly regular crashes with Team Render Client on Windows 10. Overall, it’s working well, but I will almost always get a crash. The renders are being controlled/launched from my Mac. I have two dedicated render boxes running the latest Windows 10 (not sure of the pack). A window will come up with something like “Corona plugin has crashed.” I’ve attached the Bug Report. Seems to happen with different scenes as well.
_BugReport.zip (112 KB)
Hey,
definitely sounds like a bug to me!
Can I ask you for some further information? namely: OS version of the Mac, Corona plugin version, C4D version. specs of the widows PCs could also help.
If I understand it correctly, you start a TR from a Mac and have some windows machines as TR machines?
Thanks,
Jan
Yes, it’s C4D on my Mac and I use the two Windows boxes to render. Many time, I disable the local Mac since it could slow down certain jobs. It is random though, so difficult to replicate. I just realized that the clients are not running Hotfix 1. I’m guessing it’s always best to keep the versions the same. Should I update now, or do you want to test anything first?
Cinema 4D r20.059
2013 Mac Pro Trashcan, OS Catalina 10.15.2, Full-speed non-debug version, Build timestamp: Oct 8 2020 08:44:35, Version: 6 hotfix 1
Renderbox1 - Windows 10 Pro, v1607, OS Build 14393.2189, CPU: Xeon E5-2673 v4 @ 2.3 GHz x 2, 128 GB RAM
Renderbox2 - Windows 10, Pro, v1909, OS Build 1836.1198, CPU: i9-7900X @ 3.30 GHz, 72 GB RAM
Just an extra bit of info on one of the PCs from the Team Render Machines ping: "Connection speed test indicated a high data transfer rate. Upload-118.03 MiB/s, Download-112.17 MiB/s. Network speed shouldn’t be an issue.
Please, do try to update and let me know. I don’t think it makes much sense to try to fix version differences as that is very hard and not worth usually.
Thanks,
Jan
