Corona crashes very often
I didn’t have this problem before with alpha 3 for instance, I don’t know if it comes with my overclocked sytem being unstable or else, but corona crashes so mush when I press render, mostly after changes made in materials or other things in the scene. Then I reload max and scene and it renders, some times i have to reload twice or three times, odd…
What should i do to figure out the problem?
Thank you
if you have a suspicion your system is unstable, try running some stress tests, like prime95, other renderers, etc. If it still crashes, then you need to solve a hardware problem
Well I have an Dell Precision M4700 workstation and now my bigger scenes make me crash. Everytime. I have a new Win7, and the crash started after, when I had changed something in the material editor… Maybe is it depend on the Max 2013 updates ? Because I didn’t install any updates for the max…
Ofcourse I have the alpha 5…
