Corona doesn't render Mograph Matrix object ?
Hi guys,
Does corona have problems with Mograph objects ?
It looks like it doesn’t render the Matrix object (Pics attached) - I have a matrix objects with some effectors and fields on it - I can see the cubes of the matrix object in the viewport but it doesn’t render…
I also encountered problems rendering Cloner objects to the IR - the cloners doesn’t show there (but render ok to picture viewer)
EDIT
Never mind, I made a mistake in the scene
Kobi
I am curious - what was the mistake? And is it working for you as expected now?
Well, I only started to experiment with mograph this week so it’s all new to me.
The mistake I did was that I used the matrix object as is - when you activate the matrix object you see on the screen some cubes. but the cubes we see on screen are not real - they are just hold the coordinates…I didn’t have any real object for the matrix :smiley:
Ah, I see. Yes, the Matrix object works exactly as you describe - as a holder of a set of matrices.
