Corona doesn't showing the C4D window
hello,
I installed Corona for C4D. It shows up in the plug in folder, but not in on the interface.
Do you have any idea what is causing this?
Thank you!
have you tried the instructions…??
… yes …
Try to do a manual install. Choose customize when installing, then direct it to cinema’s plugin directory.
Example:
/Programme/MAXON/CINEMA\ 4D\ R18/CINEMA\ 4D.app/Contents/MacOS/CINEMA\ 4D
