Hello there,
We have a weird problem in our office with a Corona DR. We have like 6 PC’s running, we are using DR from time to time and it just worked fine. Recently, we bought a new PC and in general - it works just as all the other PCs we got, but from time to time, while we are trying to use this PC in DR we are getting some weird stripes on renders. ( screenshot attached ). It only happens with this 1 PC. When this PC is a main one and uses the other ones on DR - there is no problem. We only have a problem when we use it as DR with all our other PCs.
Any ideas what might be the reason ? We checked Corona version - everywhere its the same. Same as 3ds version and so on.
Thanks in advance.
KM
Stripes usually mean that one (or more) machines does not have access to some textures or other assets used in the scene - sounds even more likely given it is a new machine, and it works fine if it is the main machine. What to check depends on what you are doing - if using a network drive for assets, make sure it can see it; if all machines have their own copy of all assets, make sure it has its own copy; if doing neither, make sure DR is set up to send all assets at render time.
We though so, but everything seems to be fine ( when it comes to textures and all the assets in the scene ). Im attaching 2 more screens - when we try to enable bloom and glare we even receive some rainbow
Like I said earlier - we checked all software compatibility and its updates, we checked any missing textures, assets.. We tried to uninstall Corona on this one PC and install it again and still nothing. No idea whats the problem.
When we zoom in in some areas it looks like the exposure or gamma is totally wrong at this part ?
This can take some troubleshooting. Can you send us a ticket for this so, we can look at it together?
Send your issue here: https://corona-renderer.com/link/contact-support
Regards,
Avi
