Corona DR, not working on one slave.
Hello, I have just finished to instal corona DR on my third PC..
I try to use it…
an error mesage appears:
“Cannot bind to lookback port (TCP 19667)
This probably means that some other app is already using this port (probably another instance of DR server)- shut it down first”
and an another:
“Cannot bind to lookback port (TCP 19666)
and a last one:
"Cannot open log file in directory
C:\Users\utilisateur\AppData\CoronaRenderer\DrData
Error: Cannot open/read/write file
C:/Users/utilisateur/AppData/CoronaRenderer/DrData/DrLog.txt
What does it mean?
I think I have to change Port…
Master is port 19666
first salve Port 19667
is it that, and if yes how?
thank you
Well I don’t understand… but it’s working…
in the master PC, in the render setup, my two slave are recognized and in the render viewport in DR i can find them too…and the render is working..
Do I have to modify something even though?
this definitely meant you had 2+ instances of DR server running. Closing all of them (via task manager) and starting just one will help
ok, thank you…
this morning it works well, no error message..
good but???
