Sorry for the newbie question but I have a hard getting renders rights, they are over exposed, and if I lower exposure compensation, it affects the realism of the image as well as the textures by making the result too dark and washed out. Or I have to lower down the lights intensity values to a ridiculous level such as 0.0001, which is unusable…
What do I miss there?
Thank you for helping.
Some more information, and some images or a scene to have a check?
Thank you for answering
Here are 2 examples of the same scene, the brighter one is a render at 0 exposure compensation, the corona sun is at only 1.0 intensity. The second example (the darkest) is more towards the mood I’m searching for in my scene, I set the xposure compensation to - 5.5, but look at the result, the color are washed out and dark, especially the sky.
Looks like you are not using a 32-bit file for your sky.
ok thank you for the tip
Ther is something wrong with the light setup: I can see the sun in the env. but shadow are not following the sun. What kind of setup are you using?? Env(with sun) + Corona sun???
Sorry,
But I finally found that it was the scale of the scene being very small that was causing the issue.
Thank you again for having helped me.
