We will send one of our renders to a render machine and it will pick up the job and run fine. When it comes to saving the output it seems to get stuck and wont save out, no error message or anything just sticks in the frame buffer.
The outputs always save to the shared drive we have, could this be an issue although we never really had it before…
How exactly are you sending it? Backburner? Corona’s DR? Deadline,…?
What exactly is stuck? 3ds Max? Just Corona’s VFB?
Have you tried both drive letters and UNC paths? (for example: Z:\Renders\ vs \computer-1\Renders)
Are you running some of the applications taking part in rendering as administrator? It is a known issue that apps running as administrator cannot access network drives.
