Corona for C4D A6.1 testing
Hi all,
after some internal changes in our libraries, we finally fixed conflicts between Corona for C4D and V-Ray for C4D plugins. Now, Vray should not crash when it is installed together with Corona more. This changes should also fix some UI problems like “VFB can’t be closed” or some “freezes of VFB or Picture viewer” (mainly on macOS).
I would like to ask you for testing the A6.1 version, and if it is OK, we will change the download links on Corona download page. Here are the links for testing:
macOS:https://drive.google.com/open?id=0B7xyYS3daSJ7NERxQjFMdGRiV2c
Windows:https://drive.google.com/open?id=0B7g1HtV8lD7gM2NFa3JIaEtqUXM
Thanks Nikolat will check it out.
Im on PC and I’ve been getting an issue with the C4D PV not updating the changes made in the Corona VFB after render ends so hopefully this will fix it. As a related issue do you know if we will get better export options from the VFB? Currently I have to switch back to PV for save outs in 16bit PSD.
On Mac Osx Sierra 10.12.3 Cinema 4d R18 Release 18.039 with Vray 3.4 (and without Vray) Corona A6.1 version plugin is not loaded
I tried to uninstall the old corona version but is the same issue.
Can you please download and test it again? I made a silly bug in the installation package. There is fixed version of it.
Now it works…thanks
Great! Thank you for testing.
Osx El Capitan 10.11.6 on Mac Pro 5.1
C4d R16.050 Visualize
Vray 3.4
Corona A6 crash at start
Corona A6.1 work ok
if I new I communicate as soon as possible for now everything ok
Leo
I am still getting huge freezes on Windows. At certain times the whole c4d freezes including the cVFB :smiley:
Thanks Niko, it’s working now.
