Have any one else encountered this behavior with recent patches, at least hotfix 3 and 4. I have relatively small interior scene and when I use interactive mode all is fine for a few moments then corona freezes for quite a long time. Blue circle starts rotating and when corona comes back from freeze interactive mode starts again from black screen. Now when I close interactive mode max crashes every single time. If I continue working with interactive mode on max won’t crash. It happens when I close interactive mode. This is so annoying.
I have to check if this happens with every scene or is it just with this scene I am working now. Or is this related to some objects in my scene. I haven’t had this problem always. It started when I updated hotfix updates.
I had .3ds models imported from skechup in the same file. They were hidden during rendering though. I deleted all the sketchup stuff and now max does not render anymore. But it still freezes alot with this scene. I upload the scene and freeze minidump. I couldn’t use the upload cause the file was bigger than allowed. I used the other upload method that was meant for bigger files. I hope you can solve the freezing.
Scene started crashing again. I load the crash minidump to you via uploader. This crash minidump is now separated and did not come with the rest of the files.
1523015794_3dsmax-minidump.dmp This is the name of the minidump
