Corona glass is pink
Hello i have a problem with a corona glass material.
When i open a file,glass material is pink and when i change it back to normal glass ,it changes back to pink after i reload a file.
We’d need more information please - which version of Max, which version of Corona, what material is used and what settings are used in that material, if the settings change after saving and reloading the scene (btw you didn’t mention saving the scene after changing it to normal glass, since we have to check everything, you did save the scene?).
I guess sharing a screenshot of the material setup would be essential here (or the scene itself if possible).
Corona version is 7
3ds max version is 2021
Is there a reason why are you using Physical material and not native Corona Physical. Can you try to replace it with latter and use one of available glass presets and see if that solves your issue?
The material is pink/orange even in the material editor thumbnail, so I guess it must be some setting inside that material. I guess setting up a new material would be the easiest solution, and as Romullus suggested, a Corona Physical Material with one of the Glass presets would work best.
I fixed it ,problem was scene converter at start i mechanically clicked at option to convert all corona physical materials to phyiscial materials. Thanks everyone for help.
I would suggest disabling the Autodesk scene converter.
