Why Corona keeps unchecking “Automatic saving on render end” ? I have to check it every time before render on the same project.
Is there a way to turn off EV override on VBF in 3ds max Physical camera? I use it over free camera because it has vertical tilt.
Max 2016 + Corona 1.6 hf 2
maru
2
Not sure about this one. Is this happening to you every time? How often?
Go to Environment and Effects (8 key) and make sure “Exposure Control” is set to “”. This should do the trick.
Lifesaver. Thank you!
It’s quite random tbh. I’ll test it a bit to find some pattern.
