Corona iES Light - softer shadows
Is there some way to make shadows of some IES light softer? Of course, i’m interesting how make it in Corona. For example in V-ray i know that there is “Override Shape Mode” and if you put higher value you’ll get. Do Corona has some trick like this?
Regards,
W
If you mean the “blurriness” of the shadows cast by object lit by an IES light, then you should simply select this light, and increase its size (e.g. radius if it’s a disk light).
Ok. Thanks. I’ve tested it again in simple scene and it works fine. I’ve posted because I had problem before to see the difference in interior scene
