Corona IES Problem with DR
I have been noticing that we are getting random lines in our renders since updating to 1.7.7. I believe its the IES lights that cause the issue. You can see the faint lines in the attached image. I have checked gamma on all machines and assets are correctly linked. This has happened on two different projects now. Has anyone else had the same issue? I would love to see the back of this problem
Mark
I can only guess right now, but it could be:
-some issue with IES indeed - maybe the file is not transferred to the nodes?
-an issue with our new light solver - you can download RC10 to check this, as it is disabled by default in there
We have just released Corona Renderer 1.7 Hotfix 1: Renderer for architectural visualization - Corona | Chaos
It contains some important DR fixes, so please download and install it.
Please make sure that Corona Renderer 1.7 Hotfix 1 is installed on all computers, and that DR server 1.7 Hotfix 1 is running on all of the slaves.
If the issue will remain after installing this version, please contact us, and we will continue looking for a solution.
are you using the experimental light solver?
@OP is the issue still actual?
