Corona Image Batch v13 is not working in corona v14
Could you please update the scripts for mass cxr extraction? Currently, running the .bat file does not save the files.
Additionally, I have a question: is it possible to program the script so that it reads several different lightmixes and saves each pass with a separate name? For example, I export a file with the daytime setting, but I also have a nighttime setting, and it would be nice not to repeat the same process twice, especially since cxr files are often several GB in size. When a cxr file is opened only once, the script saves lightmix passes with different times of day.
I am unable to reproduce the issue which you are reporting. I tested the batch script with a 100 CXR’s and it worked all fine.
Can you perhaps send some of your CXR’s and the scene where you extracted those CXR’s from so we can check on our end if the problem is isolated only with your data.
https://support.chaos.com/hc/en-us/requests/new
