Corona Image Editor - receive error message on missing LUT
All our files are stored on a NAS.
In the Corona Image Editor (CIE) we save a config file of the tone mapping settings for each render we process. LUT’s are stored on the NAS as well.
Every workstation (WIN10 Pro) has the same mapped network drives to different folders on the NAS.
For some reason and from time to time windows does not automatically connects to the mapped networks drives.
If this is the case you can open a render in CIE and load the conf file. It will load all settings except the LUT, because it refers to the C drive instead of the mapped network drive.
So an error message will be welcome.
Just a random thought - maybe this could be resolved using symbolic links or something like that? So CIE would look for the LUTs in C:\Program Files\Corona... but that would actually lead to the NAS location.
Hi, so basically you would like to have a warning message that LUT file, specified in the CXR, cannot be found, right?
exactely
Furthermore it would be handy to have one config file which saves tone map and light-mix settings.
OK, I will record both as feature requests. Thank you.
awesome!!
(we have it logged in our tracker)
