Hi all,
I downloaded the beta and went through the install process, but couldn’t find the plugin in either the menu or the customisation area. I came across these forum threads:
https://forum.corona-renderer.com/ Corona not showing in C4D R18 macOS #msg106550
https://forum.corona-renderer.com/ Corona Renderer for Cinema 4D, Beta 1 doesnt work with C4D R19 #msg117254
I have followed all of the the recommendations:
- Have done a custom install
- Have ensured corona plugin is in the applications/maxon/r19/plugins directory
- Have ensured corona plugin is in the application ~Library/preferences/Maxon/r19_xxx/plugins directory
- Have removed all plugins from both plugin areas above to see if another plugin is interfering with startup
Result:
- Have looked in the customise area, not found
- Not appearing in toolbar
- Not visible in select renderer dropdown
I’m not getting an error on startup, the plugin just isn’t appearing.
MacOS High Sierra, 10.13.3
Cinema4Dr19.24
Thanks all, I hope I haven’t reposted a repeat query - search only returns the forum threads above on searches related to this problem.
Thanks in advance.
Cheers
Jonathan
