Corona interactive mode with Itoo Forest cause 3ds Max to freeze.
Hi everyone,
I have an issue with the interactive mode of Corona Renderer. When I’m working with heavy scenes and I try to pan view in interactive mode and in isolate view, 3ds Max freezes for couple of minutes. I investigated it, and found out that Corona interactive mode with Itoo Forest Pack cause the freezing of 3ds max. It’s happening only when I try to pan view in isolate view. It seems that corona is trying to load all of Itoo Forest Pack instances even if I isolate just one independent object from all scene. I created simple scene to check if others will experience the same problem. I’m sure it’s not my computer problem, because I tried this in two different computers, results are equal. But I’m not sure if this is Corona or ItooSoft fault. I have latest Itoo Forest Pack plugin and 2017 3ds Max.
Could anyone please check on this simple scene if any of you experience this behavior too?
test_corona_itoo.max (892 KB)
