Corona is not set as an active Renderer ...
I have been seeing this error in Corona 9 in some of my old scenes, I have attached it below. never experienced it in Corona 8 or older. the annoying thing is when the scene is opened, Corona is not set as default Renderer and upon setting Corona as the Renderer, it obviously resets all Render setup and frame buffer settings to defaults, so I lose the settings. is there anyway to fix this problem?
It seems that these old scene were saved while Corona was not set as the active renderer.
Do you think this is the case?
Can you please try opening the same scene which brings this error message with the latest daily build/RC and see if the error still appears?
https://forum.corona-renderer.com/ Chaos Corona 10 for 3ds Max - Daily Builds Changelog #msg213161
