Corona layered material
is there some issue with using the AO map in the mask slot of the layered material? i want to overlay another map but use the AO to just affect the edges of the object but so far nothing, not sure if its a bug
It should work just fine. Could you show material setup screen?
lol, no textures are being used but whats funny is i tried it in a simple scene and it worked ok but in this scene it working and then stoped, also at first after opening and closing the file it showed correctly and then now incorrectly after i change the colors only. must state also that i am using the version attached
This
