Hey all,
Completely at a loss here. I’m trying to texture some wood and stone in my environment but the corona material library materials are just not displaying on anything, even when there is a UVW map or unwrap UVW modifier on the object. It’s weird because I have a gold texture in use too, which displays fine (probably because it has no normal maps and such). When I use the eyedropper in the material library, it picks up the material just fine, and shows what the material should look like in the preview, but NO MATTER WHAT I do, it doesn’t apply to and object?
I’ve tried to make a separate empty scene, import things in, texture them and render them, but still nothing. Even if I make a new environment with nothing but a sphere and light and try to render a texture on said sphere, it still does nothing.
Please god help me i’m dumbfounded.
The eyedropper tool picks the material from the object that you select not the other way around. You can simply drag and drop the material from the editor on to your object.
Hi Rowan,
I’m not sure what you mean- I open the corona in-built material library and select apply to selection, and whilst the colour of the object changes, the material doesn’t show, even in renders with a UVW map applied. When I eyedrop the material from the object (with the corona material applied, so I can see it in the material editor) the material is fine in the preview, despite not showing in viewport or renders. If I drag and drop the material nothing changes, as it is the same material as it was when I applied it from the corona library. The issue isn’t applying the material.
Cheers!
Hey Maru,
Thanks for the reply, real-world scale was already enabled on both the diffuse and normal maps. I tried disabling them to see if it fixed it, and whilst it darkened the colour of the object, it still yielded no texture on my object, still just the block colour, even in render.
Could you please send us an example scene like this (with all assets included, using the File>Archive option) and then let me know which upload method you used and what was the file name?
The uploader is here: Chaos
Hey Maru,
I’ve sent in an archive, entitled ‘Eggscene’, I uploaded it directly to the link you send (didn’t use the dropbox option, if that’s what you mean by upload method).
I was getting an error message when I archived, but still got a zip file from it, so something may be wrong. If there’s an issue let me know and I’ll try fix that ASAP.
Cheers!
So I think you need to select “real-world map size” on your objects. If I add a box into your scene I get the same results until I tick “real-world map size” then the material is displayed as it should be.
Hey Rowan,
Thanks for looking into this, is there a way to apply this setting to my existing objects? I’ve tried following that link you sent me but I can’t find the option for my already existing objects.
Cheers!
Hello!! I am having the same issue today. I already did what rowmanns and maru said but the material still doesn’t appear in render.
I am using 3dmax 2021, corona render 7
The thing is that some days ago it was working just fine, and now I am having some problems with some materials in render, but in viewport it looks ok.
The solution which worked for the original user was enabling the “use real world size” option for their objects. You can either enable it in object settings (for example the 3ds Max procedural geometry like planes, boxes, teapots, etc have it in their UI), or you can add, for example, a UVW Mapping modifier and enable the real world size option there.
You can find out more here: https://forum.corona-renderer.com/Corona Material Library v2 - Real World Scale vs Triplanar Map
