If I run two instances of Max on my same laptop
I get an error that all licenses’ are being used.
I was looking at another similar question but did not see an answer
In many instances I am busy with one scene and whilst that renders I carry on with another scene, it seem I can only run one instance of Max ?
We will double check it, but if you start 2 or more instances of 3ds Max with Corona, regardless of what you are doing, only 1 interface license + 1 render node license should be engaged. The limit is not per 3ds Max instance but per computer.
Could you share your registered email address with me through a private message? I would check the details in our records.
Also, which exact version of Corona are you using?
