Corona Light - 3ds Max VS Standalone
First of all, Thank You for A7!
I noticed a different interpretation of Corona Light in Corona Alpha V7 3ds max 2015 and Corona Standalone V6:
In Standalone, the light appear, even if the “Visible directly” option is deactivated at “Export scene…” moment.
Does anyone know a solution to remove the appearance of light in Standalone rendered image?
I found a tip in “Corona standalone input format description” https://corona-renderer.com/wiki/standalone :
“Use geometry with materials that have Ke set to non-zero to create lights”
What does it mean “Ke set to non-zero” ?
Ke= the stage name of New York singer/songwriter/actor Kevin Grivois
ok,i dont actually know.
might be key.
ke is the emission koefficient as much as I know. So if your material has a non black emission color, it is turned into a light.
