Corona Light Tag
It will be handy if we have Corona Light Tag, it will easier in older files and with other render engine files.
Place tag and do minor required settings instead of change all lights and resize and position it.
Thanks.
You could also use the character command “replace with”. Select the C4D light, “replace with” then select your Corona light. :wink:
