I often use lights in cloner objects in the past no issues. With Corona V3 the lights render only as white lights.
CoronaIssueFile.zip (4.89 MB)
Looks like the Color control in the Transform in the Cloner now affects the color of the lights it is instancing - this may be as designed and intended (the devs can say for sure). You could restore your scene without rolling back by copying the color from the light itself into the Cloner Transform color.
