Corona Lights very bright in Viewport
When I place lights, they are very bright, they blow out the image and make it hard to see what I am working on. This is with Gouraud shading. It looks great in the render, but very blown out in the OpenGL viewport. I turned on Enhanced OpenGL and turned on the setting that makes Corona materials view properly in OpenGL as well, but neither has fixed the issue.
It might be a combination of the material used in the room which is adding to the over-exposed look. What does it look like if you switch to Gouraud Shading (Lines)?
