Hi
I have completed a search, and only found two Items of this nature on the form.
I have completed Max Model and Corona materials. I have Tried the Vray converter and nearly everything is black.
Max 2020 Corona 7, want to move it to Vray 5 update 2.2…any help?
Did you use the New Corona Physical material?
That isn’t converted on our end (nor they do allow conversion to a standard, that i know of.).
EDIT: There are ideas on how to get those shaded on our end, but they aren’t implemented just yet.
Hi I tested your scene and indeed the issue is with the CoronaPhysicalMtl. V-Ray scene converter currently does not support it. This issue is scheduled for fixing under VMAX-11097 in our system.
To integrate on what has been already written, i’m currently writing a converter, ETA is unknown for now.
Fair warning, a few things will not be 1:1 identical.
Thank you very much for all the help.
You know the way it goes , you run into these things when your on a deadline.
So I appreciate the help.
Yes Physical materials are the issue I have been informed by the team.
I am not amd about them anyway for the Arc Viz work.
The Corona convertor makes everything Physical and that drives me nuts, a lot of changing things trees bushes etc…
I will know for the future.
I have a version ready to be field tested (before it goes into the usual set of conversion scripts).
Please PM or mail me so to arrange it (you may test yourself, or send me a relevant scene and i’ll do the testing on my side.)
