Corona Material Library and Motion Blur
Hi Guys!
I found two issues on my scenes:
I downloaded corona 1.7 with the material library, then i’m using Compact Material Editor and when i turn on interactive mode and i drag and drop the materials from the Corona Library into my material slot to replace and older material for a new one, the Interactive windows does not update.
If i drag and drop the material library into an object inside the viewport everything works good, but sometimes when you have car paints or things like that it’s easier drag and drop it into the material editor to replace all the objects that are using the car paint than drag and drop one by one into the viewport.
And the second thing i noticed, i have my car moving on the road with the camera linked to the car (so both are moving with the same speed) when i turn on motion blur, the car its blurried and it supose not be like that.
Any idea?
What type of camera? Even more relevant now there is the CoronaCamera :smiley:
Do you have motion blur turned on for both objects and camera? Is the camera targeted at all?
Thanks! problem solved i just turned on one of the blurs, only geometry! But with both blurs turned on it works!
Thanks a lot
Most welcome :smiley:
Hi, as for the drag&drop … is the material actually dropped and only the interactive view does not reflect it? or the material is not dropped (received by the slot) at all?
