Corona Material Library - Controllers
I would like to suggest something to the maker of the Corona Mats.
Adding Controllers to some of the elements can result in overal smaller amount of tweaks that has to be done to properly set material.
Regards
The problem with controller nodes is that if you drag material with them from a library to the editor, controllers are hidden by default and that might confuse some users. Also i’m not sure if controllers can be accessed in compact editor. Could be problematic if someone would want to unlink linked nodes. Nevertheless, controllers would be nice to have in Corona material library, it’s just that they are implemented in awkward way from Autodesk side (IMHO).
In that case this should not be added in.
as the library is now intended primarily for beginners, this would be an overkill
