As I understand; all Corona materials (from the material library) are set to mm (millimeters). Is this correct?
I always work in MM, however occasionally, and I can’t figure out why, how or when, the materials seem to apply at an entirely wrong scale (sometimes cm, sometime m, sometimes even bigger).
Any idea why this is happening? Am I missing something? My workflow is to usually import from Rhino, if that makes any difference. But I always start in mm, and import from Rhino in mm.
I’m new to 3DS Max/Corona, so please excuse potential amateur errors. Any help appreciated! Thanks.
another thing. If you like many others scales things on object level in Rhino, then this will give a result like what you describe when imported in Max. If that’s the problem, you need to reset X-form on those objects (Utility tab).
My scale is set to mm. I make a 3000mm x 3000mm x 3000mm box and apply a corona wooden texture to it. It applied perfectly.
When I import a model (from Rhino, also built in mm, and exported at mm, and imported at mm) and apply the exact same material to the imported geometry, the scale is WAY off. I have to decrease the ‘real-world scale’ by 1000 for it to display correctly. Same goes for imported geometry from Sketchup
The suggestion of trying reset xform hasn’t helped.
Any suggestions/tips/hints welcome…Thanks!
Edit: When I apply UVW map modifier to the object, without changing the scale, ie; keeping real-world scale, the texture scale suddenly appears correct.
Sorry for the delay.
I checked your model and it seems it has uvw mapping baked in it. This won’t work out of the box with RWS mapping, so the solution is to either apply some simple uvw mapping such as box, and enable “real world scale” option, or use the tips from this thread: https://forum.corona-renderer.com/Corona 2.0_use real world scale
The Corona Material Library is intended to be used in scenes with mm as units and if a material contains the CoronaTriplanar texture map you will need to adjust the scaling of the map to fit (so divide the value by 10 if your scene is in cm).
For objects imported from other software that seem to have the wrong scale, make the object the size you need then apply the XForm modifier then convert the object to an edit poly or edit mesh. This should fix the scale mismatch issues.
However, resetting xform doesn’t seem to help. I previously presumed this was a issue with importing from Rhino, but now I’m working on a file from ArchiCAD (imported as *.obj) and I have the same issue - I import objects, apply a corona preset material and it’s scale is 1000 times too big. I have to add ‘UVW map’ modifier, untick ‘real-world size’ and input the L,W+H as “0.3” in the case of most of the wooden materials.
Hitting ‘reset xform’ as you’ve suggested doesnt help this. Am I missing something?
