Corona-Materials.de is online
Now it’s done, the material library for Corona for Cinema 4D. Although still in beta, but you can already full use of. Share Your materials and fills the database!
http://www.corona-materials.de/en <<
Sven
Nice idea man!
Please make a big thumbs material. For that would be understood better bump and the texture of the material))
Nice work!
Lovely stuff. Would love Corona Material library being properly revived for 3dsMax.
Also Deutsch vs Englisch translation inconsistencies.
Do you mean a greater material view? That’s done.
Thanks for the tip. I’ve corrected.
Nice work
could you have solution: when we load .c4d from material manager, texture path is broken
thx
well done!
Do you mean the preview scene (Download) or one of the materials?
what exposure/compression settings I should use? Since corona vfb doesn’t save these values from scene to scene
UPD:
oh, nvm, found these values in render settings
Can’t register According to“set the check mark in the captcha box(spam protrction)"
Can you see the captcha box?
Where I can’t see?
Is in your browser maybe an ad blocker or a script blocker? Here the captcha box must be visible:
A few bugs have been fixed and on the material site can be written comments. It also there are many new materials:
Good job!
Cool!!!
Nice to see this kind of stuff in early development of the plugin…
Thumbs UP!!
Browsing through pages of materials doesn’t respect sorting
Your site have so much better visual design than http://coronamaterials.com/
Looking very good!
I am wondering - does corona material for cinema have identical settings like corona for max?
If it does, maybe it would be possible to build software independent library.
Also, I am wondering about writing a scripts, which would send material directly from your website to max/cinema material editor, and download needed maps to some pre-setup directory on harddrive. This would greatly speed up the workflow!
Sadly it’s platform independent at the moment. I’m really hoping they release a universal stand alone node based material editor. They would just need a decent batch of proceedurals and layer system.
Yes I know. But it would be quite easy to develop exporter for both softwares, which would create simple JSON file, with all the material informations - values, colors, map paths, etc.
Then, importer/interpreter for each application would have to be developed. Based on information stored in JSON file, it would reconstruct material in platform specific way.
Both importer and exporter could also access database directly. Data like corona version would be passed automaticaly, and even thumbnail creation could be automated.
I don’t see much problem here. Only procedural maps could be the case here as you mentioned. I’ve never used Cinema, but I suppose that procedurals like noise and falloff are all available.
If not, procedural baker for some maps could be incorporated.
I might develop some proof of concept quite soon. For max/cinema pc version.
