Hi everybody! Just started learning Corona, I’m following this tutorial
and I’m having trouble at around 7 min.
He uses a MixMap to blend the diffuse texture with a leakage texture, assigns the leakage to channel 2 and then uses a UVW Map assigned to channel 2 in order to spread the leakage in a more realistic way.
I followed the same method but the my UVW Map doesn’t change the texture in any way, is driving me kinda crazy, any solution? Pic attached
edit: I also tried to use a simple diffuse map instead of the AO+diffuse mix but it doesnt work either way
re edit: for some reason the UVW Mapping actually works in the rendering but I’m unable to see the change in viewport. any idea how to fix it?new pics to show the difference
