Hey guys, when using the Take System and under a Take other than the main Take, the Mask ID box is greyed out and there is no way to override this attribute.
You need to tick the autotake button(see the icon attached), to make changes only on this take.
Meanwhile you could enable the Id you need, globally, unticking autotake, and clicking the Main level of your take system set up, as you suggest it.
Cheers,
Nelaton
