Corona multitexture
I have an old Corona project that needs to be updated and rendered quickly. I was hoping to use Vantage but I’m getting black surfaces in Vantage. I was able to use one corona bitmap in the diffuse slot and it worked fine, but I have 6 bitmaps linked to a corona multitexture node. Does Vantage not support that? Is there a workaround? The other thing I’m running into is strange. I have this one wood texture that I linked to a new corona physicalmtl like the others it doesn’t render, like the others. It renders black. Like if my bitmap is missing. Can’t figure out why. 3dsmax 2026, V 2.1.1 and I’ll have to check, but the latest Corona.
Can you please try enabling the “object buffer ID” in multi texture and see if it solves your issue? If not, can you please send your scene by starting a ticket so we can check your material setup? Submit a request – Chaos Help Center
r​
Found out the issue. I had a single Coronaphysicalmtl with a coronabitmap that was 18k in size. Once I lowered it to 4k, it showed up. Now I have a question about corona lights showing up in reflections even if all the toggles are unchecked.
