Hello friend,
I have a question about corona node material textile, if you could give an warmful reply, that will be appreciated and glad.
I exported a png picture for digital “8” like below from Illustrator, I connect it to diffuse texture and copy it to connect to opacity texture and click this png picture layer setting as alpha channel. My target is make the “08” picture on the above of the object surface, but now it’s turn upside down from above and bottom, I guess that if the reason of pivot x+ turn left? So my question is how can I set the node material editor to make the digital “08” turn to reverse normally but don’t change the viewport?
Thank you very much!
