Is it possible to have the corona opacity map when rendering with Vray next ?
Until V4 it was not possible and it is very annoying when you always switch between these two render engines..
Thanksa lot
Regard
mienda
Thanksa lot
Regard
mienda
I am sorry, but I don’t fully understand this post.
What exactly do you mean by “Corona opacity map”?
Can you show a simple example of what you are doing and what is happening?
Sorry for my english!
I will try to be clearer. When I try to render with Vray a corona material with an opacity texture (in the opacity slot), the opacity texture remains opaque. it is very embarrassing and certainly very simple to correct in corona.
I hope I have been more understandable!
thank you
This is something that we need to fix on the V-Ray side; will make a note about it.
